cbr 900 rr 99 model
Old Oct 10, 2007 | 08:18 AM
ge2000's Avatar
Default cbr 900 rr 99 model
Guysi just got a honda 900 cbr 99 model i just want to know ,when u start the bike dose the raditor fan work at the start or not cos my one it work at the start.
Old Oct 10, 2007 | 08:58 AM
stynkmonkey's Avatar
Default RE: cbr 900 rr 99 model
It will only kick in when it needs to, usually after you've been running for a while and the engine is really warm. Just like in a car.
Old Oct 10, 2007 | 05:02 PM
grubeda7's Avatar
When your temp gauge gets up to 217-219 the fan will kick on. Glad you joined the RR club! :-)
Old Oct 10, 2007 | 07:51 PM
SpiritRR's Avatar
The fan should not come on at startup. Does it stay on all the time? What does the temperature gauge read, even when the bike is cold? Is there enough coolant in the radiator? It sounds like you are saying the cooling fan comes on when you start the bike, even when it's cold. If so, you may have a faulty thermo sensor or temperature guage. If the rest of your cooling system is working normally, the fan motor switch may be faulty.
3 is the fan, check the connections, 16 is the thermostat switch, try replacing it if everything else is working
Old Oct 15, 2007 | 01:49 AM
petrorr's Avatar
mine kicks on at 220 deg.
Old Oct 15, 2007 | 01:39 PM
gixxereater's Avatar
Someone probably wired it to run all the time. Follow the wires back, they are probably connected to a switch now for manual use.
Old Oct 16, 2007 | 04:58 AM
dinez74's Avatar
I had this problem at one time.... I pulled over the fuse and fix it back. Since then the fan was operating normal.
Welcome to the club...
Old Oct 17, 2007 | 11:00 AM
1badeg's Avatar
ORIGINAL: ge2000
sounds like the fan switch has been bypassed or the switch is bad......normally the fan should kick on anywhere from 215 to 220 degrees. Some 900rr's are different in temp, but, other people would agree that 215-220 is the normal range.
Old Jul 27, 2009 | 02:29 PM
ccain's Avatar
I hate to dig up ancient threads but...On my 97 CBR900RR, before I got the bike, some wingnut wired my fan to a toggle switch. Probably due to a faulty switch. Can someone tell me where the fan switch is located on the engine? Thanks
dont_fear_the_Reaper
Jul 15, 2011 01:40 PM
lptwist
Nov 30, 2008 03:41 AM
ramarjagreb
Jan 5, 2008 11:01 PM
Coopz
Jan 21, 2007 09:22 AM
LoNeProBE
Jun 13, 2006 07:44 PM
