cbr 900 rr 99 model
RE: cbr 900 rr 99 model
The fan should not come on at startup. Does it stay on all the time? What does the temperature gauge read, even when the bike is cold? Is there enough coolant in the radiator? It sounds like you are saying the cooling fan comes on when you start the bike, even when it's cold. If so, you may have a faulty thermo sensor or temperature guage. If the rest of your cooling system is working normally, the fan motor switch may be faulty.
3 is the fan, check the connections, 16 is the thermostat switch, try replacing it if everything else is working
ORIGINAL: ge2000
Guysi just got a honda 900 cbr 99 model i just want to know ,when u start the bike dose the raditor fan work at the start or not cos my one it work at the start.
