Can I turn my rotors?
Old Jul 23, 2012 | 06:30 PM
bubbamcf's Avatar
Default Can I turn my rotors?
Hey all my front rotors are warped on my 98 900w and I was looking on ebay for a new set, first I'm wondering if I can turn or resurface my rotors? Anyone ever done this? Second, will all Blade rotors work or just 98/99? Thanks
Rick
Old Jul 23, 2012 | 07:20 PM
Shueisha's Avatar
Personally i'm not a 100% sure, but if you can I would say it's best to just get new ones for safteys sake.
Old Jul 23, 2012 | 07:48 PM
MadHattr059's Avatar
To answer your question on turning, yes it's possible.
The trick is finding out what yourrun-out is (how warped the rotor(s) are),
and then seeing if you can still have useful spec when you are done turning them.
You'll need a dial-mic and a base for it. I attach mine to the fork,
add a slight compression to the tip past touching the rotor,
then rotate the rotor, observing the maximum and minimum readings.
Subtract the minimum from the maximum and you will have your run-out.
Then take a micrometer and measure the thickness of the rotor. Subtract the run-out
from the current thickness. This is what your rotors will be when finished turning.
If that still meets the spec for minimum thickness on your rotors,
it can be turned to true.
Personally, you should add (imo) .2mm to .3mm to that to allow for future wear,
when making the call.
As an example, my F3 manual shows 4.8 to 5.2 as stock thickness.
The minimum is 4.0mm.
The maximum tolerance for run-out is .30mm.
If the current run-out is .70mm, I have to shave .40 (usually .20 per side)
to get back to the maximum tolerance.
I would shoot for .15 to .20 (again for future wear) meaning, I actually need to take
off .55 to .60mm (or .275 to .30 per side).
If the disc is currently 5.0mm thick, that means I'll end with 4.35 to 4.4mm of meat.
That works and I still have a decent margin.
If the disc was less than 4.75mm? Then, NO I would not pay to turn, I would replace.
At that point, you will be less than my (admittedly, arbitrary) minimum for extended/useful life.
Hope this helps you in your decision process, Ern
Old Jul 23, 2012 | 08:30 PM
Piranha's Avatar
^+1
Old Jul 24, 2012 | 05:10 AM
bubbamcf's Avatar
Thanks I haven't checked the runout of the rotors yet. If they are un turnable has anyone used the Chinese rotors from ebay? I ride only street, not really a super aggressive rider. I do plan to have this bike for a while though...
Rick
Old Jul 24, 2012 | 07:39 AM
vfrman's Avatar
Party Animal, ROTM June 2014
Brakes are very important to your survival.... is this a part you really want to go the cheap route with? If it were me, I would stick to either stock parts or reputable aftermarket.
Just my opinion tho.
Old Jul 24, 2012 | 09:42 AM
Motleyfan's Avatar
March 2013 ROTM
I agree 100%. I looked at the cheap rotors from China on ebay when I was redoing my 96 900 but thinking my life is worth more than a couple of hundred dollars I went with Galfer wave rotors. More $ but great brakes and definately more peace of mind.
Nick
Stunt'n70f4i
Sep 6, 2010 10:52 AM
RyanEricW
Aug 10, 2010 12:34 AM
Lowridese
May 1, 2010 01:12 AM
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
