a broken motor! is not mine.
Old Apr 17, 2008 | 08:41 AM
mertan's Avatar
Default a broken motor! is not mine.
i have a friend with an 900 rr and he look-out in motor. and he find this! i dont know what is the problem ho make this. i thing a distribution problem. de valves heat the piston. is my opinion. what you think about it....
http://i96.photobucket.com/albums/l1...6/DSC06695.jpg
http://i96.photobucket.com/albums/l1...6/DSC06692.jpg
Old Apr 17, 2008 | 05:38 PM
CBRwarrior's Avatar
Default RE: a broken motor! is not mine.
Reading that hurts my eyes.
As far as the piston,I can't tell, but is it missing a valve? The pictures are a bit hard to see even up-sized. Is that a hole punched in the center of the piston? If so, I'd imagine it ate a valve, the other cylinders look pretty good though. I'd be worried about damage down inside the case from fragments of metal from either the valve or the piston. I hope if he rebuilds, he breaks the case and makes sure everything is clean of debris.
Omaha rider
Jun 27, 2011 11:22 PM
burner
Nov 13, 2006 05:42 AM
sublyme
Sep 16, 2006 03:02 AM
