brake help
brake help
when iam riding the bike it makes a real loud grinding sonud and starts wobboling likes its fixint to fall ouver or have a flat tire when i take the brakes off it doesnt do it the brakes are pretty worn almost completly gone but i dont think that would cause that but iam no expert either i dont think the roter is bent cuz i was riding it and about 30 mins in to the ride it started can some one shead some light on what going on here
RE: brake help
Well, i would start by replacing the pads. If nothing helps there, i would blead the brakes (always good to do anyway) and clean the caliper pistons. Does the brake lever pulse when on it? Sounds like the pads are not coming back from the rotor (cleaning the pistons will help this). Did you recently re-install the front tire? Are the fork tubes straight with each other? Loosen the pinch bolts and roll the bike up to a wall of some sort and gently rock it back and forth (NOT using the front brakes to hold it) against the wall to straighten them out and sinch up the pinch bolts.
RE: brake help
First off ,I'm no english teacher, but use some periods man lol. That might not have less to do with the brakes than you think. First off, check your tire pressure for sure. You say you don't think your rotor is bent..... find something straight (maybe a file) and put it up against your rotor or somethin like that. Also, your steering head nut, ya know the one on the triple tree in the middle? I hope thats torqued to spec and you have a good bearing. Are the brakes binding? Does it do it at all speeds? More info
RE: brake help
you got your front axel bolts all tightened up? Sounds stupid but there are a million possibilities with front end wobble.. well maybe about 15.. :-P
Hey Crazyhorse! .................................................. .................................................. .... I got an A im emgwish!! lol
Hayden06F4i
06-17-2008 09:50 AM
