whats is an ignition advance
Old Jun 21, 2006 | 12:34 AM
alte22a's Avatar
Default whats is an ignition advance
can someone explain what am ignition advance do? hows it work? what are the benefits and the down side?
Old Jun 21, 2006 | 12:54 AM
gixxereater's Avatar
Default RE: whats is an ignition advance
Read this, it'll help you with the pros/cons and what it'll do for you.
http://www.rrzone.com/forums/showthread.php?t=2331
Old Jun 21, 2006 | 01:06 AM
kaynott's Avatar
aight Im convinced. So where can I get ahold of one?
Old Jun 21, 2006 | 05:11 AM
duck0872's Avatar
calsportbike.com has them here be sure to tell them you're a cbrforum member
Old Jun 21, 2006 | 05:18 AM
kaynott's Avatar
thanks bro...
Old Jun 21, 2006 | 04:03 PM
gtjimm's Avatar
i did a search on the web to find out more info on it cause I'm still not sure how it works, and what the cons are. Some people (especially the yamaha guys) say that it doesn't do anything. How many people use it and is it definately worth it. Basically, will it hurt to try, or to use for a prolonged length of time?
Old Jun 21, 2006 | 11:57 PM
I havent tried it yet, but it's not going to hurt anything to try. You're out $40 if you dont like it. I have only heard a few say they think it cost them power, but they are going by the seat of pants dyno. Everyone I've seen that dynoed the bike afterwards say it either helped power output some, or smoothed out the power band. Wont hurt to try it. And no, pro longed use wont hurt anything. Your timing is probably retarded a touch too much so it will pass emissions from the factory. All it does is advance your timing 4 degrees. It will fire the cyclinder 4 degrees earlier in the crank rotation as opposed to stock. Say stock is 32 degrees before TDC, this will make it 36 before TDC. Usually equals more power. Longer, more burn on the combution stroke.
Old Jun 22, 2006 | 12:55 AM
alte22a's Avatar
thanks gixxereater sort of thing that I wanted to hear. Its was all a myth before now its less will try and see how I get on with one.
Old Jun 22, 2006 | 01:55 AM
lang1864's Avatar
i didnt see one on the list for an RR. Do they make one. and if someone gets one let me know how it is. Im thinking of doing this. THanks
J
Old Jun 23, 2006 | 01:03 AM
kaynott's Avatar
bro I have contacted several people about this particular IAU for an 05 600RR. No luck at all. Im thinking our best and only bet is to buy the dyno jet ignition box. Its tuneable up to ten degrees forward or backward in the crank cycle. Its pretty pricey though, btw $300 and $350 depending on where you get it.... OH yeah and you have to have the power commander, its a piggy back style style system
s1rusdvirus
Sep 2, 2008 09:51 AM
01929er
Jun 3, 2008 12:11 PM
89cane
Feb 14, 2008 05:20 PM
alcala87
Nov 25, 2007 08:31 PM
slowpoke
Sep 9, 2006 02:30 PM
