ignition advance
Old Aug 8, 2006 | 11:35 PM
slowpoke's Avatar
Default ignition advance
My 1990 feels sluggish below 4K, so I grabbed my old timing light and checked the timing advance. It's on "F" at idle, but stays there until around 4K then advances to the advance line. I don't think this is normal. I think it should be advancing somewhat between idle and 4K. Has anyone checked their timing with a light? Does it advance smoothly or jump at 4K? Do I need a new spark generator?
Old Aug 20, 2006 | 06:25 AM
R1000's Avatar
Default RE: ignition advance
ORIGINAL: slowpoke
The ignition pulse should come like 5 or 10 degrees (BTDC) at 1000 rpm and smoothly increase to about 40 degrees advance at 5000 rpm (or higher rpm depending on version). The spark generator is fixed, and the variable advance function is within the ECU.
Old Aug 20, 2006 | 02:20 PM
slowpoke's Avatar
Thanks R1000, looking forward to replacing the ECU.
Old Aug 24, 2006 | 05:56 PM
R1000's Avatar
ORIGINAL: slowpoke
Have you received the ECU yet?
Old Aug 24, 2006 | 08:42 PM
slowpoke's Avatar
Didn't come today. Hoping for tomorrow.
Old Aug 30, 2006 | 01:43 PM
R1000's Avatar
ORIGINAL: slowpoke
It should have come by now, has it?
Old Aug 30, 2006 | 08:41 PM
slowpoke's Avatar
They don't call it snail mail for no reason. Plus, Colorado is in the middle of the country. I'm driving my wife crazy, because every time I come home I ask about the mail or go look myself. I will let you know when it comes. Actually, I'll put it on the bike first, test ride it, then let you know that it came.
Old Aug 30, 2006 | 08:53 PM
R1000's Avatar
ORIGINAL: slowpoke
To bad for you, hope it has not been ranked as a dangerous ignition device and destroyed []
Old Sep 2, 2006 | 09:22 PM
BackTalk's Avatar
John
You probably already did this, but have you tried Steel's for the ignition part? They have surprised me many times with parts for my 87 over the years.
BT
Old Sep 3, 2006 | 02:14 PM
slowpoke's Avatar
ORIGINAL: BackTalk
John
BT
Steels, Denver's motorcycle boneyard. We went there to get a regulator for my friend's 1978 Suzuki GS1000. It uses a separate regulator and rectifier, both with huge cooling fins. Couldn't find any. So we got a combination R/R from a Yamaha and just hooked up the regulator wires. All R/R's are pretty much the same, but now he has a spare rectifier he can hook up if he has to.
