throttle response
Old Jul 12, 2008 | 08:06 PM
dudutzu905's Avatar
Default throttle response
when i'm riding and i just _slightly_ increase the throttle from the off position, the bike will jerk about some and start
accelerating. The same with rolling off the throttle
before to start this thread i've been reading all the posts about throttle
somebody said "throttle "jerkiness" are really just inexperienced riding technique"
Old Jul 12, 2008 | 08:31 PM
Tacoma25's Avatar
Default RE: throttle response
That is just something you are going to have to get used to.The throttle is really touchy at low engine speeds and is basically the nature of the bike. I have gotten rid of it over time by training my throttle-hand, but it catches me off guard sometimes. I also think it helps to have a properly adjusted chain as well.
Old Jul 12, 2008 | 08:45 PM
DuDuTzu's Avatar
i checked the chain - is fine...
I have PCIII but i think i should reset it or readjust it
the only way i can ride it smooth is to take 2-3 seconds to roll the throthle very very gently[:@]
the fact is that i had an F4 before and the difference is huge!!! i mean, being so touchy
Old Jul 12, 2008 | 09:05 PM
FlashBazbo's Avatar
Yep, it's "normal." Not good, but normal.
Old Jul 12, 2008 | 10:42 PM
Bell407's Avatar
A little hesitation coming on throttle from idle is normal, and is a good reason to carry a little thottle all the way through a turn (slightly open, not idle).
But 2-3 seconds doesn't sound normal to me at all.
Old Jul 13, 2008 | 12:41 AM
RedRider07's Avatar
Make sure chain is tight, but in lower gears until you get into the power band a hesitation is normal.
Old Jul 13, 2008 | 06:18 AM
DuDuTzu's Avatar
the chain is tight,
and maybe isnt 2-3 seconds, but is that point in middle of the 0 position and xx position and kinda runs ****y, is almost undetectable, but if you pay attention and you get the throttle in that point you can feel it, is a tiny bit but it is, so im thinking that i should change the map on PCIII, or to try set someway the throttle in there
NickLande
Nov 6, 2021 06:26 PM
owensjt71
Dec 4, 2008 01:54 PM
dannutz
Mar 14, 2008 09:37 AM
brandonrs5
Aug 11, 2007 02:24 AM
