Temp.
Old Apr 29, 2008 | 11:04 PM
Tillys600rr's Avatar
Default Temp.
ok iv done something and idk what i did but my temp gauge is now in Cel. instead of Far. and I dont know how to change it back help please LOL...
Old Apr 29, 2008 | 11:10 PM
dwschultzy's Avatar
Default RE: Temp.
You should be able to change it by pressing and holding both the buttons on the dash. After a few seconds you should see your time flashing.After that you will press the select button to get to where the temp c/f is flashing. Next press the reset button, this should change it back to the F setting. Now press the select button until your out of the programming menu.
Hope that helps.
Old Apr 30, 2008 | 12:25 AM
Papi Chingon's Avatar
Default RE: Temp.
i think it also depend on what screen you are looking at right now. i could be wrong, but i think that you change it on the main screen ie. the screen that has your total actual miles, not the trip a and trip b. check your manual because that happened to me once and it was an easy fix.
Old Apr 30, 2008 | 06:53 PM
xxenycejattxx's Avatar
Default RE: Temp.
play with the buttons man!!!
and know about ur ride!!!
Keep the pressed for 3 seconds and then press the right button to change everything!!
Hope it workss!!
WangDangger
Apr 27, 2012 12:17 PM
codye352
May 29, 2011 03:02 PM
onefastRR
Apr 6, 2010 08:58 AM
02hondacbr954rr
May 21, 2008 09:45 PM
