Temp.
You should be able to change it by pressing and holding both the buttons on the dash. After a few seconds you should see your time flashing.After that you will press the select button to get to where the temp c/f is flashing. Next press the reset button, this should change it back to the F setting. Now press the select button until your out of the programming menu.
Hope that helps.
Hope that helps.
i think it also depend on what screen you are looking at right now. i could be wrong, but i think that you change it on the main screen ie. the screen that has your total actual miles, not the trip a and trip b. check your manual because that happened to me once and it was an easy fix.
cBrentb
Dec 24, 2011 07:53 PM
