starting trouble
Old 01-08-2008, 11:43 AM
tonyB11's Avatar
Default starting trouble
im having problems with my 03 600 rr. whats happend is i bought it used freom a private seller and it started great when i bought it tilll the next day so i then took and got a whole newignition drove it around a few times and it was great. now its been sitting for about 2 months and it wont start. i started it once inbetween the 2months with no problems..i tryied charging the battery but its saying its charged..any help is greatly appreciated..thanks tony
Old 01-08-2008, 05:23 PM
Default RE: starting trouble
what are the symptoms? you're going to have to elaborate as to what happens when you switch the ignition to on (visually on the dash and audibly), what happens when you hit the start button (noises and the such), and the condition of the bike ie the bike is in gear, the kick stand is down, the run switch is in the off position, the bike was disassembled recently...
BTW, find a 2005 or 2006 Regulator Rectifier module and replace the one on the bike. the 2003 has problems...
Old 01-09-2008, 09:59 AM
tonyB11's Avatar
well the first time i went to start it every light up fine but i tried to start it and it would just click..then the next time only the nuetral light would be light up but not much and when i trun the key on the needle wouldnt even move at all .
Old 01-09-2008, 05:28 PM
Fantastic. Thank you very much.
sounds like a dead battery. unfortunately, it may be because of your Regulator/Rectifier Module. the 2003's and early 2004's have a very bad design flaw with the mounting bracket for the R/R. The cure is a replacement R/R and mounting bracket. you can snake one off a late-2004/2005/2006 cbr600rr for peanuts. your battery might be fine, it might not be. Charge it up using a 12VDC battery charger capable of supplying a 900mA rate for 10 hours. if this is not possible, use a regular automotive size 12VDC battery charger on a 2A charge rate for 5 hours. your maximum charge rate is 4A for 1 hour MAX.
should be good to go after all that.
Old 01-09-2008, 08:04 PM
ORIGINAL: knightslugger
d@mn now thats a diagnosis in full effect
Old 01-10-2008, 08:07 AM
tonyB11's Avatar
awesome.hopefully its the battery..thanks for help man
gonzosport9
07-03-2013 01:24 PM
jbomb
04-18-2013 06:22 AM
DragonCBR
05-30-2009 08:40 PM
bluestanger66
06-23-2007 08:52 AM
9two9
05-08-2007 12:06 AM
Quick Reply: starting trouble
