sprockets and chain
Old Jul 10, 2007 | 06:02 PM
thrush06's Avatar
Default sprockets and chain
i have a 06 600 rr and i just went a tooth down in the frount and two teeth up in the back.. i was just wondering how bad this would throw off my mileage and speed.... does it make the gauge cluster read that it has more miles on it then it actually does ?... and should i purchase a speedohealer?
Old Jul 10, 2007 | 06:35 PM
baxsom's Avatar
Default RE: sprockets and chain
a speedohealer is a good idea for even a stock geared bike
your combo will make the speedometer read faster than you are really going
get a speedo healer and have it clocked at different speeds to find out the average error and then go to the speedohealer website to get the programming switch code
Old Jul 11, 2007 | 04:55 PM
thrush06's Avatar
alright thanks man , does the sprockets make you bike milage go up while ridn ... i do understand that the mileage will go up while riden... but does it make it say that it has more on the bike then what actually is ?
Old Jul 11, 2007 | 05:22 PM
Drekkyk's Avatar
I think your milage will go up. If your speedo reads 70 mph, and your really doing 60mph, then in one hour your bike is going to say it has 70 miles instead of 60.
Old Jul 11, 2007 | 09:02 PM
baxsom's Avatar
yes the speedohealer will also compensate for mileage as well
when you go to their website to determine the correction value is will ask you the % speedo error and wether you want it to calibrate for speed, mileage, or both
Old Jul 13, 2007 | 08:03 AM
tyson_rr's Avatar
yea but how do you go about getting it radared with no access to a radar gun?
Old Jul 15, 2007 | 08:21 PM
thecannibalchef's Avatar
just repeatedly drive by a "this is how fast you are going" sign, and record the speed on the gauge, and your actual speed, divide one into the other, and this is the % error. in other words, if it says youre going 36 and youre going 40, you take 36/40, which is 0.9, which means your speedo is off by 10%. same thing i always deal with when i run big tires on my truck, except the error is positive instead of negative.
HydroPrelude85
Mar 6, 2013 09:00 PM
ganzey
Jan 31, 2012 03:15 PM
kowen1208
Apr 20, 2010 08:45 AM
NEboardr
Aug 7, 2008 11:20 AM
angryscientist
Oct 1, 2006 10:21 PM
