Shaking problem
Old Feb 17, 2006 | 12:29 AM
cwoody28's Avatar
Default Shaking problem
I recently replaced my clutch discs. They were completely burned out (1 - 3) It was makeing the clutch catch almost at the very top. So I replaced the clutch discs and did everything exactly as how I should have. The next day it was warm enough to take outside to start. So I started it up and adjusted the clutch levers and freeplay. Then I was seeing where it was catching. When I did this it started shaking and then after it caught it went away and ran normal. Is this mean that it need to just wear in or did I do something wrong. I did not get a chance to take off normal because its a little icy out. Also when in idle I hear a little noise. Its not loud but I can tell its a little different. If you can help me out I would really appreciate it. Thanks!
Barnett Kevlar (brand I switched stock with)
justing66
Jul 1, 2014 06:34 PM
dpeach06
Mar 14, 2008 01:37 AM
devildef2002
Oct 19, 2006 04:48 AM
VP
Aug 19, 2006 05:13 PM
vego12
May 31, 2006 02:22 AM
