removed engine, now it wont start.
Old Mar 12, 2008 | 02:24 PM
steve00ses's Avatar
Default removed engine, now it wont start.
Well i had to drop the engine to get my shifter fork and two gears replaced. So After i get it mainly back together i cant hear the fuel pump prime...the starter is kicking over but nothing after that. I did put the front clip back on too for the tip over sensor...
My question is does anyone know or have seen pictures of a teardown? like somebody do a do-it-yourself thing and take good pictures of the wiring or anything? I knew i should have but was a idiot and didnt. So other than me taking it all off and starting over...im kinda out of ideas.
Old Mar 12, 2008 | 02:28 PM
bobjoezx's Avatar
Default RE: removed engine, now it wont start.
go and check your connections for the fuel pump, it's in the tank, also check fuses and such..
Old Mar 12, 2008 | 02:45 PM
steve00ses's Avatar
Okay there was one wire i cant find the end for it... i have the half coming from the airbox but where is the other half coming from?
Old Mar 12, 2008 | 02:48 PM
bobjoezx's Avatar
hm where, take a picture
Old Mar 12, 2008 | 03:00 PM
steve00ses's Avatar
Not my bike..but exactly the same wire. http://cbrworld.net/photos/tutorials...3/500x375.aspx
Old Mar 12, 2008 | 03:01 PM
steve00ses's Avatar
Its in the circle A part.
Old Mar 12, 2008 | 03:05 PM
bobjoezx's Avatar
hm not totally fimilair with the routings of the 600rr.. but here is a diagram of the wiring hardess
let me knwo if this helps you and i will keep researching
http://216.37.204.206/wps/Honda_OEM/...A=437&B=52
if i remember right that is def your problem why you dont hear the fuel pump
Old Mar 12, 2008 | 05:15 PM
buster369's Avatar
www.mrcycles.com has a break down of the whole bike. On the left side of the bike by the front of the fuel take, there are three relays. One is for the fuel pump and this was the problem on my bike.
Old Mar 14, 2008 | 12:06 AM
steve00ses's Avatar
Well i found the wire, and for the fuel tank there is two wires that looks jsut the same...make sure you check...one has 2 prongs and one has 3. Started up and running strong!
Syned
Jun 4, 2017 04:56 PM
matt56us
Dec 1, 2011 04:43 AM
crxgt2004
Oct 29, 2009 11:23 PM
i23soul
May 4, 2009 09:38 AM
cbr_newbie
Dec 17, 2006 12:41 PM
