Rear heat shield ??
Old Oct 1, 2005 | 05:31 PM
Tribal_Steve's Avatar
Default Rear heat shield ??
The Fender... GONE... Signals.. GONE... Reflectors.. GONE.... Tag? Thanks Comp Werks. Signals? Thanks Clear Alternatives. Quiet Exhaust? NO MORE... thanks Two Brothers..
So any foo.. I did the clear alternatives tail light today. Not bad. Was disapointed in the fact that they did not bother to put connectors on for the signals... these are cheap to do... and make me guess at the wiring for the signals? How Hoaky... but it seems to work well... I disassembled the factory signal ends on the fender side, kept the ground out, and just used the hot hire.. cut it soldered, and heat shrinked.. bam, looks factory. good enuff..
So any way, my dilema. With the Two Brothers, and the factory heat shield still there it looks like ***. I was going to cut the sides off, and just trim it to the contour of the tail... but then, why can't I just get rid of it? The carpet fiber, farbon ciber... (snicker) can runs cooler then stock...
Anyone just taken off the rear heat shield all together to expose the sides of the exhaust? Any negative effects? more heat in the ***? anything? If so, I'll just trim it, and figure a way to trick it a bit... I have somethig in mind, and will take pics if I do it. Thanks in advance.
Old Oct 2, 2005 | 10:36 AM
doncollins's Avatar
Retired Administrator
Default RE: Rear heat shield ??
I've read on here somewhere that someone removed the heat shield and said it didn't make a difference. I've look for it but I can't find it... but I do remember reading it.
Old Oct 3, 2005 | 12:34 PM
Davev13's Avatar
I have the Yosh RS-5 carbon fiber exhaust and they supplied a piece of aluminum tape to replace the heat shield. I haven't had any problems with heat from the exhaust.
Old Oct 3, 2005 | 01:07 PM
Mr Bling's Avatar
I have had mine off for awhile and I have the clear alternatives signal light and a Akro and I have had that bike hot before yet to have any problemes probably 5000 km on it set up this way I took off all of my heat shields off of the side to it's sort of nice this time of year warms up my legs and keeps my passengers a bit warmer too lol
Old Oct 3, 2005 | 09:44 PM
josho66's Avatar
Ya I got the Yoshi and they give you one. You can get the heat shield stuff that is adhesive, like tape, at autoparts stores. That way you can remove the stock one, put on the new kind and have the best of both.
JamieDenny
Apr 27, 2014 06:15 PM
Stephens
Sep 28, 2009 06:48 PM
xmurfx
Apr 23, 2009 02:19 PM
billywobbles
May 13, 2008 01:18 AM
cbrrookie
Mar 23, 2006 07:52 AM
