radiator fan removal/install
RE: radiator fan removal/install
Try this web site to down load the service manual. If you scrool down enough you will see a link for 03-04 CBR600RR's. The fan removal should be the same.
http://www.bikechatforums.com/viewtopic.php?t=41567
If your talkin about the bolt on the top of the radiator. you need a socket wrench and a long extension. I had to take mine down when i was putting on the new exhaust.
When you get the bolt out, the frame piece that holds it on at the top has a sort of nipple that keeps it in place along with the bolt. you have to wedge it sideways a bit to get it to come off.
