Oil Weight
Old Jul 23, 2007 | 10:20 PM
sixhundredrr's Avatar
Default Oil Weight
Well, I did my first oil change. 3.5 hours (thanks to A/M header and being my first time) but I didn't scratch/break anything and got all the hardware back on. The manual says 10w40 and my dumb --- did not check before buying/draining my oil. So, I purchased Honda HP4S 10w30 full syn instead of 10w40. Do you think it will be a problem? My riding is mostly commuting and my bike is an 04 RR. It shifted/rode fine on the way home but I'd appreciate some input.
Old Jul 23, 2007 | 10:31 PM
Blue Fox's Avatar
Retired Moderator
Default RE: Oil Weight
I run 20w50 in the hotter months and 10w40 in the cooler months. I'm not sure about 10w30 though. Should be fine, but I would wait for a few more replies to see what other people have to say that are more oil-literate than myself.
Old Jul 24, 2007 | 01:14 AM
zerochickenstrips's Avatar
It's fine. I personally think that fully synthetic oils are pretty much a waste of money, though. But 10/30 will not damage anything. Honda wouldn't have it in their chemicals line if it damaged their bikes.
Old Jul 24, 2007 | 05:27 AM
Thanks for the input. I figured it would be ok, but I wasn't 100%.
Old Jul 24, 2007 | 05:34 PM
baxsom's Avatar
considering that my 07 manual says 10w30
i think you are ok
oil weights have an overlap in heat range anyway
if it starts to run a little hot
then go to the 10w40
Old Jul 25, 2007 | 07:54 PM
Denn10's Avatar
10/30 vs 10/40 both 10 weight at operating temp just one is 30 weight at room temp vs 40 so once you warm it up its all the same. I dont see any problem at all with this.
Old Feb 18, 2010 | 11:26 AM
Nick2727's Avatar
Im using Shell Rotella T synthetic. Read halfway down this article and you will understand why it is BY FAR the best for your bike (http://motorcycleinfo.calsci.com/Oils1.html).
underground-mpyre
F2 Tech
Mar 21, 2010 07:35 PM
BeachingCBR
Oct 31, 2008 12:01 AM
Turbokaos
Apr 24, 2008 06:15 PM
Tori
Jun 26, 2007 08:55 PM
PierPressure
Feb 27, 2006 10:56 PM
