oil filter question
#21
Yes I believe that different blends will have different effect on shifting because it be a different thickness or viscosity. However personally I would stick with what the manual says to use because unlike a car where you have different oils to run the trans, engine and rear end, the oil in bike does it all. Personally I think a lot of research and testing went into determining what oil to use in these bike. If you do decide to try a different oil just make sure there is no molybdenum in it as it will make the clutch slip.
#22
