not sure if this is a problem or not
RE: not sure if this is a problem or not
ORIGINAL: BlindLOKI
i will take off an run it slow so as not to annoy the neighbors
ORIGINAL: cbr04
hmm... yeah... i'm with tahoe... this is not normal. i've ridden in the teens up here in IL and when i start it up i've never had that problem. you probably don't need to rev it while it's warming up. in fact, when it's COLD out i don't touch the throttle till it hits 100 degrees on my temp guage.
Yeah, just hit the starter and let it sit until it hits like 140ish degrees. I wheel mine out on the driveway, fire it up and let it sit until at least 140-150 degrees while I get my gear on. When the bike's cold, so is the oil. You want that oil up to temp also or else it's not going to flow where it needs to be while you're giving it revs while cold.
dewthedoo05
09-04-2007 09:32 PM
