Noise at 5000rpm - reality or paranoia?
Old Sep 11, 2006 | 08:04 AM
brkic's Avatar
Default Noise at 5000rpm - reality or paranoia?
Dear all,
Ive owned my 06 rr for a few months now and i have noticed that at around 5000rpm ( mostly in 2 and 3rd gear) it makes a noise - like a vibrating screw - which doesnt sound right. Ive spoken to my local mecchanic on the phone and he said its usually the valve caps, that on the rr's vibrate a bit too much.
however it doesnt sound right - and why would i not have noticed the first day but two months in?
any advice? do you gutys have the same noise?
Old Sep 11, 2006 | 12:00 PM
Fretless33's Avatar
Default RE: Noise at 5000rpm - reality or paranoia?
It's coming from the gas tank cover and the tank...the pieces vibrate right around that RPM range...there is a write up on every 600rr forum about this, so you should be able to find the fix if you do a search!
Old Sep 16, 2006 | 12:02 PM
Blue Fox's Avatar
Retired Moderator
Yep, the fuel tank cover. There's a small piece of plastic rubbing up against the inside of the cover. I thought something was wrong at first too. Doesn't hurt to leave it alone. In fact, mine has gone away (bike's 3 months old now).
Old Sep 16, 2006 | 12:09 PM
tjcoyle's Avatar
It's real.. check out my response here:
https://cbrforum.com/m_160015/tm.htm
Stephen Baty
Mar 22, 2013 11:04 PM
cbrvenn
Sep 20, 2009 08:37 PM
Blaq675
May 13, 2009 03:55 PM
Cbr-norway
Apr 2, 2009 01:47 PM
caneridah
Feb 10, 2009 11:40 AM
