Leaking coolant
Old Jun 29, 2006 | 10:04 PM
sthiravong's Avatar
Default Leaking coolant
I am leaking coolant from the left side of my bik out of two small hoses near the kick stand. Where do those hoses go and why is it leaking?
Old Jun 30, 2006 | 12:20 AM
gixxereater's Avatar
Default RE: Leaking coolant
Leaking out of both hoses? I can only guess as I dont have your particular bike, that they are the radiator and return lines from the pump to the radiator and back. Probably have a loose clamp? Or perhaps it has a small cut? Seems odd that both would leak. Most likely one is dripping on the other or getting tossed up there from turbulence while riding? Just a few guesses.
Old Jun 30, 2006 | 12:58 AM
Fretless33's Avatar
One hose is an over flow from the gas tank and the other comes from the radiator reserve tank, it's possible some fluid leaked out of the reserve tank. Check and keep an eye on the coolant level, tighten your clamps and inspect the hoses.
Old Jun 30, 2006 | 12:32 PM
knightslugger's Avatar
If this is the case, as Fretless33 seems to have it nailed down to, your bike is ok to ride. Just keep an eye on it. you don't want that overflow to run dry. It may be just a case of your engine running a bit hot. when you check it, check it cold.
Old Jul 31, 2011 | 08:11 PM
ricky0880's Avatar
I've had the same thing happen the last couple of rides ,just a drip or 2 coming from the coolant over flow hose .i've been learning clutch wheelies on the bike reving it high and hard u think this could cause it ...and its been real hot out the laast couple of rides ...
atf1001
May 7, 2013 01:14 PM
kapsiak
May 6, 2012 12:41 AM
vtchopperdude
Sep 26, 2010 08:42 AM
Conna
May 26, 2008 04:11 PM
shinysideup
Jan 12, 2006 09:34 PM
