CBR 954 leaking coolant
Old May 26, 2008 | 11:43 AM
Conna's Avatar
Default CBR 954 leaking coolant
I had an unpleasant surprise last night, I noticed my bike had starting leaking coolant and it was puddling below the bike. I figured I could ride home and see what's up so I poured the contents of my water bottle to the the coolant tank. After a few kilometres though the engine started heating up unusually high and the tank was almost empty so I had my friend pick me up in his van and take me and the bike home.
Well, today I stripped the fairings and this is what I found:
http://i25.tinypic.com/v3jfva.jpg
http://i32.tinypic.com/vp7u6d.jpg
It was dripping of the circled bolt, there's some marks of it running down the cylinder too although I didn't see a leak anywhere else. I just idled the bike though so those might have come yesterday, I was riding it properly before I noticed the problem. Anyone know what's up with this?
Old May 26, 2008 | 02:20 PM
t4rusaf's Avatar
Sept. 2011 Ride of the Month
Default RE: CBR 954 leaking coolant
Just tighten that bolt up, no need to worry about it; that is one of your drain bolts for your coolant. That one is for the engine block and the other one is located on the water pump housing.
Old May 26, 2008 | 02:50 PM
Conna's Avatar
I took it out to check if the grooves were busted but it looked all right, no coolant came out though. That's because it only circulates when the engine is running, right? I put it back in as tight as I dared and idled the bike and it still leaked. It should probably be done with a torque wrench, anyone know the specific torque for it?
Old May 26, 2008 | 04:11 PM
justasquid's Avatar
Once you remove that bolt, you need to add sealant to it again. It wont seal on just the threads alone.
atf1001
May 7, 2013 01:14 PM
kapsiak
May 6, 2012 12:41 AM
sthiravong
Jul 31, 2011 08:11 PM
vtchopperdude
Sep 26, 2010 08:42 AM
shinysideup
Jan 12, 2006 09:34 PM
