leaking coolant
Old Dec 28, 2005 | 03:05 PM
shinysideup's Avatar
Default leaking coolant
turns out that one of my hose clamps broke from a radiator hose durring my slow speed spill. funnt thing is that one of the hoses is leaking and it isnt one of them. also, that plate on the engine that all the hoses connect to is dripping coolant from one of the bolts in the back. any of you had the same problem. nothing looks cracked and the hoses look good. what do i do. when i get it all fixed up, im selling her!!!!!!!!!!! ill absolutely die if this happens again.
Old Jan 10, 2006 | 12:50 AM
RideorDIe199's Avatar
Default RE: leaking coolant
mines doing the same thing, it has never been crashed and i have 3300 miles on it, mine is leaking coolant at the back of the engine also. havent had a chance to investigate, what did you find?
Old Jan 12, 2006 | 09:34 PM
i found that the water pump cover has 2 small cracks by the drain bolt. i dont know how, but 2 of the hoses were leaking too. i took them off, checked them, and put them back on. i have ridden it once since and havent checked to see that the leak is still there, but i do need a new water pump cover
atf1001
May 7, 2013 01:14 PM
kapsiak
May 6, 2012 12:41 AM
sthiravong
Jul 31, 2011 08:11 PM
vtchopperdude
Sep 26, 2010 08:42 AM
Conna
May 26, 2008 04:11 PM
