Integrated Taillight Problem
Old Mar 11, 2008 | 11:19 PM
Woody6799's Avatar
Default RE: Integrated Taillight Problem
Im 99% I did not wire it incorrectly... I have tried resistors and cant get them to work, as far as pulsing wires when tested neither pulse, solid green shows constant ground while the other color is the positive and flashes when set off. And I have found the fuse box... The front signals turn on and run solid yellow as does the rear when that is hooked up before getting the ground spark. The only thing I could think of is bad flasher or bad taillight
Old Mar 12, 2008 | 07:42 AM
shoortbuss's Avatar
I want you to look at something VERY closely. Look at all of your signals and make sure they are not blinking EXTREMELY fast as opposed to being solid. This is a fine line, but will tell alot. When I first hooked mine up, I THOUGHT they were solid, but upon closer investigation I realized that they were blinking at such a ridiculously rapid rate that they just seemed solid.
Think of it like a movie...just still pictures, but put together it gives the illusion of motion.
Old Mar 12, 2008 | 11:00 PM
Woody6799's Avatar
Ok say it is doing that shortbuss.... I have 5 resistors on it and still did not nix the problem.... suggestion?
Ozzie De La Rosa
Apr 12, 2014 10:43 AM
zweber376
Jun 19, 2013 12:33 AM
cbrizzle
Jul 18, 2007 01:11 AM
