idle issue
Old Mar 30, 2009 | 11:20 AM
dwschultzy's Avatar
Default idle issue
04 cbr600rr
bike idles fine in neutral....when put into gear it jumps up 2k in rpm's
ideas?
Old Mar 31, 2009 | 03:01 PM
Baooo's Avatar
had an issue with mine idling at 5k. sorry i dont know name but ill try to explain what was wrong with mine. Their is a cable that connects under your throttle body. Mine sits out on left side of bike under the plastics, its a black cable and has phillips screw on the end. try adjusting that and it may help i found out mine broke and i had to replace the cable and idle control valve thing it went into. only 75 bucks from dealership so good luck
Old Apr 4, 2009 | 10:42 PM
600RRWatson's Avatar
idle air control valve (IAC) it routes air around the throttle blades at idle and at open partial or wot it should stay closed but if your having a issue with the idle its prob sticking or freaking out for one reason or another
JHillCBR
Sep 23, 2012 11:34 PM
Avodka14
Nov 14, 2011 10:05 PM
1989cbr600F
Jun 29, 2011 05:30 AM
Mondstar77
Dec 21, 2009 05:05 AM
MetaLord 9
Aug 24, 2009 06:52 PM
