How to set idle speed?
Old 06-10-2009 | 06:28 PM
Pistol_Pete's Avatar
Default How to set idle speed?
Does anyone know how to set the idle speed for my 2003 cbr600rr?
Old 06-10-2009 | 06:37 PM
FLYOU's Avatar
it's that round black **** in the top left of the pic.
Old 06-10-2009 | 07:29 PM
sUshI's Avatar
yea, just make sure bikes warm before you go messin around. 1/4 turns, dont go all twisting like its on fire or anything.
Old 06-10-2009 | 09:43 PM
i thought so but mine doesnt seem like it changes anything. The rpms are fine when i start it but once it warms up t drops below 1000 . i have to give it a little bit of throttle to start it.
Old 06-11-2009 | 08:26 PM
Turns out it was stuck. I just traced the tube out to find the spring and gave it a dose of wd40. A few wiggles later it was perfect!!!
Old 06-12-2009 | 05:53 PM
sUshI's Avatar
always something retarded...or booze induced.
Old 10-18-2009 | 02:30 PM
SwedishPhish's Avatar
Hey guys, I'm new to the forums. I have an '05 that's having the same problem; bike idles at 1500 or so when cold, but the warmer it gets, the lower the idle until eventually it won't idle unless I give it some gas. The bike runs great at low and high speeds, and you wouldn't know anything was wrong with it until you came to a stop light and it died on you. I've tried new gas, and the idle adjustment screw (I can see the screw going in and out up inside the bike, so I know it's not stuck.) The idle adjustment doesn't seem to do anything, either. Is there any way to adjust the throttle cable? Also, turning the idle adjustment screw which way does what? The manual is incredibly vague on this...
Old 10-20-2009 | 03:50 PM
03cbrsix's Avatar
what RMP should it be at a normal temp for 2003 cbr 600rr?
Old 10-21-2009 | 01:53 AM
MikeGST's Avatar
I think I read it should be around 1300rpm's
500tie
03-06-2013 11:01 AM
Mako
04-23-2009 08:05 AM
david_ozey2002
02-06-2008 10:28 PM
Jaybird180
09-24-2007 01:42 PM
geoffb2003
07-08-2007 07:19 AM
Quick Reply: How to set idle speed?
