how many volts should the pink wire from the ignition to the fuel pump have on 600rr
Old Nov 20, 2007 | 09:18 PM
Manubi's Avatar
Default how many volts should the pink wire from the ignition to the fuel pump have on 600rr
[hr]
how many volts should the pink wire from the ignition to the fuel pump have on 600rr ??
with the key on.
please help my fuel pump wont kick on !
its an 04 600 rr[/align][/align]the pink wire should be easily accesible running from the ignition back under the tank into a plug.
if somepne could just stick the tip of there muti meter into the pink wire somewhere in between the connector and ignition it would tell them what voltage im needing.
right now im readin 5.8v after the resistor... and before the resistor im getting a ****ed up reading that jumps up and down between 98v all the way back down to 30v and back up everywhere inbetween[/align]
Old Nov 20, 2007 | 09:42 PM
knightslugger's Avatar
Default RE: how many volts should the pink wire from the ignition to the fuel pump have on 600rr
did you check the fuel pump cut off relay?
Old Nov 20, 2007 | 09:53 PM
Manubi's Avatar
ORIGINAL: knightslugger
dnt think so..
where is it and how do u check it?
Old Nov 20, 2007 | 10:22 PM
you don't have a service manual? and you're troubleshooting the electrical system?
eek.
it's located under the left side mid fairing. it's the first relay from the left. get a manuel before you go any further though.
http://www.stephygee.com/600RRmanual.zip
Old Nov 20, 2007 | 10:51 PM
Manubi's Avatar
yeah.. just got the bike not even a week ago.
i thought it might be that relay. it clicks when i turn the key.
download the manual.. any idea how ot check it off the top of your head ?
eek.
Old Nov 20, 2007 | 11:06 PM
i forget. with and without 12VDC i know that.
ORIGINAL: Manubi
eek.
Old Nov 20, 2007 | 11:26 PM
Manubi's Avatar
k
going through the manual now...
Old Nov 23, 2007 | 10:49 PM
Manubi's Avatar
got the new plug in today
and the feul pump kicked right on and the bike started up soon as i pluged in the new ignition.
Caleb Sneeringer
Jun 29, 2013 06:00 PM
woodgolf
Aug 11, 2011 10:05 PM
kokopelli
May 1, 2008 01:31 PM
mojo
May 26, 2007 06:18 PM
cyco
May 4, 2006 04:47 PM
