Help!!! Did I blow a fuse.
I was installing my FE.net kit on my '06. Everything was going fine until I try to hookup my license plate light. It doesn't work. I then notice my gage cluster isn't on. I can start the bike, the headlights work, the brake light works, and the turn signals work.
The gage cluster doesn't work, the back running light doesn't work, and the license plate light doesn't work.
Did I blow a fuse? If so, which one and where can I find it?? Thanks for any help.
that happened to me when i was doing my flush mounts. its the main fuse and its on the left side behind the farring. if you take the farring off theres a little box right there open it and you will see the fuses. i think its a 20 but i cant remember for sure. if you look in your manual it tells you where its at as well. hope that helps.
