Headlight Problem
My headlights will not turn on when the bike is running. I think it may be the wire that connects inside the ignition switch housing after reading about lots of others having this snap off from normal wear.
IF that's not the culprit when I check tomorrow, which fuse controls headlight operation?
Also, my front turn signals are not illuminated when the bike is running, but will turn on when i turn on my turn signal for that side. But when they turn on it stays a solid illuminate, it doesn't flash. The wiring looks fine. Fuse issue maybe is causing this?
Any input would be appreciated, thanks.
