headers to close to oil filter
Old Apr 15, 2011 | 01:03 AM
philthethrillohio's Avatar
Default headers to close to oil filter
ihave a 06 cbr600rr I recently put on a micron serpent full system, i noticed the oil filter sits like a quarter in or less from it. anyone have this system? i was thinking i might need to loosen the slip on to get room in the exhaust. anyone have any expiernce with this exhaust?
Old May 6, 2011 | 02:01 PM
Pistonempire's Avatar
Take off your lower fairing. Use a oil filter socket on a extention. Turn your front tire and put the socket on first. Slip the extenaion through the header in the front and loosen. Shimmy the filter through the side or bottom.
Old May 6, 2011 | 03:39 PM
jeffjones's Avatar
FAIL.
Do you have a longer oil filter?
If so you could go down to a shorter one?
If not I dont have an answer for you.
Old May 7, 2011 | 07:58 AM
Holy misread thread batman. Lol I cant believe I did that. jeff is right if you have a long filter you might be able to fix it by installing a smaller one. My friends 929rr had the issue. Switched to a shorter mobil 1 m108 filter.
Old May 7, 2011 | 05:55 PM
im using a amsoil filter and really dont want to change thatbut if it means i dont have to loosen the exhaust then ill go that route. should change the oil here soon.
you guys did read thaht i do have a micron full system thats does include diffrent headers. i had no problem with the stock headers
usndocjaysin
Sep 21, 2007 10:18 AM
1BadCBR07
Jun 27, 2007 12:55 PM
outsider8
Sep 29, 2006 05:12 PM
