handle bar is vibrating
Old Jun 8, 2007 | 10:54 PM
volcomrr's Avatar
Default handle bar is vibrating
well ive been trying out wheelies, poppin em up in first and since im not trying to shift to second, and ride it all the way up close to the redline, it sets down pretty hard, so im thinking its causing a slight vibration in the bars, forks, etc.... think its a bolt or something coming loose, has anybody else had this problem, i think i need to go through the whole bike and tighten all the bolts, thanks
Old Jun 9, 2007 | 12:48 AM
krash's Avatar
Default RE: handle bar is vibrating
and who said wheelies arent bad for bikes?
definately check everything out. It could be many different things, bent rim, loose axle, neck bearings, maybe even busted fork seals, twisted forks, etc.
Old Jun 9, 2007 | 06:16 AM
Ludefreak's Avatar
Wow makes me wanna start poppin wheelies....
Old Jun 9, 2007 | 07:12 AM
Blue Fox's Avatar
Retired Moderator
I highly doubt that a bolt came loose. You probably either bent a fork, bent the wheel (which would cause vibrations the faster you go), knocked the front out of alignment, etc. etc.
I'm willing to put money on the bent wheel (or just slightly bent to the point where the wheel is out-of-round). You should be able to take it down and have them re-balance the front wheel. They'll either weight-balance it up to snuff and fix the problem you'll know something else is wrong.
Either way, as you probably already know, bikes aren't built for stunting.........and the result is usually broken parts or broken bones.
Old Jun 9, 2007 | 12:44 PM
meanstrk's Avatar
You may want to check to make sure your wheel bearings are still turning smooth.
Try practicing shifting to 2nd while you have it up for smoother landing or work on the balance point more.
As always, PLEASE don't stunt in traffic!
Old Jun 11, 2007 | 02:24 AM
onelife's Avatar
x2 on the bent rim man arent wheelies cool
asides
Jul 23, 2011 01:41 PM
slvr05wrx
Aug 23, 2007 05:20 AM
morpheous283
Jul 27, 2007 11:41 PM
ezarj
Jun 19, 2007 04:00 PM
nathankeister
Oct 15, 2006 06:07 PM
