Getting my hands dirty
Old Mar 19, 2008 | 09:09 PM
crashkhanman's Avatar
Default Getting my hands dirty
Tomorrow I will finally put to use my countless hours of reading suspension write ups and adjust my '07 RRs suspensionfor my weight. 205lbs fully geared. I will start with the Sag and go from there if time/weather permits.
Now, my question. I've come across a few different opinions forsag numberbut this is what I'm going for. Any more opinions are welcomed. I do 90 percent of my riding in the mountain twisties and roads are pretty well paved and smooth. However, I do not want to make my bike unsafe for street use. Will these numbers be, do you think?
Front Total Sag: 35mm
Rear Total Sag: 25mm
2nd Question:
Is this good advice: "You want your bike to use as much front suspension "travel" as possible without "bottoming out" (no more travel) even in extreme conditions."
Old Mar 20, 2008 | 10:52 AM
FireStourm's Avatar
Default RE: Getting my hands dirty
Hey figured id help ya out and give your thread a bump. All though I really dont know sorry bro.
Old Mar 21, 2008 | 04:44 AM
So I did alright. After 3 measurements, I came out with 35mm front sag. and 30mm rear sag. I didn't have the C-spanner tool availiable to me to adjust the rear preload but know where I need to put the rear shock at.
After doing that,I played around with the compression and rebound a tad in the front. Man!! what a difference. A completely new bike. Its amazing how well the bike handles and inspire confidents even over the stock settings. I will keep dialing in the suspension tomorrow when the temp hit 65 degrees
Old Mar 21, 2008 | 08:07 AM
be vertical's Avatar
I really need to do this, but dont have much knowledge on it. Currently all I did over stock was tighten her up all around. Im a fan of stiff suspension. Crash can you send me some links on suspension dialing DIYs? Thanks.
Old Mar 22, 2008 | 10:41 AM
Woody6799's Avatar
IDK about the sag numbers on the RRbut I will agree that that is sound advice. As far as adjusting suspension and its improvements I can attest to that. I had a 2001 Katana that I rode for a while before I readjusted the suspension and wow what a difference. I adjusted the rear shock to the recommended number for my geared weight and then added 1" spacers in the front fork tubes to compress the springs more for a stiffer ride... it felt like a totally different bike. Now I am on the RR and have not yet dived into the suspension work although I am sure I will at some point, right now its just such an improvement over the Kat im not ready to tamper lol
Old Mar 22, 2008 | 12:46 PM
Sure vertical.
Woody, you're right. Its a whole new bike. I dialed in both my Sag, Rebound, and Compression. The bike is soooo flickable and sticky. Almost as if the tires aren't even there....lol
TucsonHonda
Sep 5, 2011 01:08 PM
rangerscott
Jun 21, 2008 02:07 PM
Martin_D
Mar 18, 2008 04:50 PM
PYRO929
Feb 14, 2008 08:30 AM
Martin_D
Jan 29, 2008 12:51 PM
