engine surge?
Old 06-26-2008 | 06:31 PM
Jreed8721's Avatar
Default engine surge?
my engine hiccups when i engine break VERY slowly at 6.5k rpm. and by very slowly i mean it's as light on the throttle as i can be without letting off of it. or if i maintain that same throttle at 6.5 it only bounces about .2k up and down and gives little lurches but it is still really **f bomb**(haven't actually read the rules yet )annoying and I am worried whatever is causing it might lead to more problems and lots of $$$ down the road.
anyone have any ideas of a diagnosis? or have heard of something similar happening
thanks
[align=right] [/align]
Old 06-27-2008 | 12:59 AM
Jreed8721's Avatar
Default RE: engine surge?
this isn't looking good, ahah
Old 06-27-2008 | 09:07 AM
shoortbuss's Avatar
Fuel injected CBR's have 2 fuel injector's per cylinder...below a certain RPM you run on a single injector, but once you hit a point, both injectors kick in. This is called dual stage fuel injection, and a problem with this would probably cause the problem you are describing...on the 05 the injector kicks @ 5500 RPMs though. What year is your bike?
Old 06-27-2008 | 12:52 PM
Freak*06RR's Avatar
That could also be caused by an aftermarket exhaust. Do you have a slip on? if so that sometimes causes a studdr or hiccup, and you will need to have it jetted to fix that problem. If you dont have an after market exhaust then could be fuel injectors or plugs....hope that helps
Old 06-27-2008 | 01:00 PM
shoortbuss's Avatar
ORIGINAL: Freak*06RR
I think you mean he needs a power commander, not jetted. Agreed that the lack of a PC with a full system COULD cause problems, a slip-on alone shouldn't cause any. We need more details here Jreed...
Old 06-30-2008 | 06:49 PM
Jreed8721's Avatar
sorry for not replying to my own topic for so long, was out all weekend.
It's an 07, I was also thinking it might be exhaust related. I only have the stock exhaust on there but when i went down last month it bent the tail WAY up along with the exhaust and I just had them bend it back and 'repair' it.
Thanks for all the info
Old 06-30-2008 | 06:55 PM
skitzofrenzy's Avatar
slip- ons can do something, but not much hiccup wise.
my f4i used to hiccup rom my 2 bros.. not a big deal but it was kinda annoying during engine breaking
Old 07-02-2008 | 01:19 PM
shoortbuss's Avatar
Oh, ok, your the dude who posted the "remove a headlight" thread. Did you ever get the problem referred to in this thread figured out?
pete 99
08-31-2011 06:55 PM
stephen83
10-27-2009 02:46 PM
Mikes03954RR
04-24-2008 12:06 PM
hustlin1ninja
10-20-2007 04:15 PM
upononef3
01-04-2007 06:00 PM
Quick Reply: engine surge?
