Chain tension
Old Feb 18, 2005 | 12:56 AM
BlindLOKI's Avatar
Default Chain tension
Hey guys, i was just curious as to how tight/loose my chain is supposed to be. I have a 2003 CBR 600 RR, and the chain seems a little loose to me, as I can wiggle it a good 2+ inches, and if it is off... what do i do [:'(]
thanks,
Chris
Old Feb 18, 2005 | 08:26 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Chain tension
Stop!!!!! While I am of the opinion that more slack is better than no slack (common chain killing error) 2 inches is way too much. If you've never adjusted your chain before, don't worry -- it's easy. You're gonna need a torque wrench with a big socket (1000RR takes a 1 1/4")
Loosen the axle nut but don't remove it. You have an adjusting bolt on both sides of the swingarm held tight by a jam nut. Get two wrenches -- one to hold the adjuster bolt and the other to loosen the jam nut. O.K. both jam nuts should be loose now and the axle nut should also be loose. Now you will tighten the adjuster bolts 1 flat at a time (looking at the bolts from the back of the bike you'd turn 'em to the right to tight). Every time you tighten the bolt 1 flat check the chain tension. When your tension gets between 1 1/2 and 1 1/4 retighten the jam nut making sure the adjuster bolt doesn't move. When you tighten up the axle nut to spec it'll draw out another 1/4 inch of slack and leave you at 1 1/4 to 1 inch.
Important: all adjustments should be done while bike is on the sidestand. When tightening the adjuster bolts make absolutely sure you adjust each one the same amount and only go 1 flat at a time. You'll have to check the owners manual for the torque on the axle nut - I don't know what it is on the 600RR.
Old Feb 18, 2005 | 11:48 PM
BlindLOKI's Avatar
thanks man, ill try er O_o
Arthur48
Oct 24, 2016 06:59 AM
jamescbr87
May 30, 2012 10:59 PM
raj1976
Aug 20, 2009 05:26 PM
tombooze
Mar 10, 2007 01:24 PM
koelzer18
Mar 19, 2006 08:12 PM
