cbr 600rr 04 wont start first time
Old Jul 1, 2013 | 06:48 PM
Mojouk's Avatar
Default cbr 600rr 04 wont start first time
Can anyone suggest a reason it wont start first time
my mechanic changed the spark plugs...
it still wont start first time...
hes saying its to do with the
immobiliser being so old...but i dont buy that.
Anyone know what reason could be...
ill turn it off and on again a couple of times and itll start
once its warmed up it tends to be better...
could it be that where the sparks fit just needs a clean?
Old Jul 9, 2013 | 12:20 AM
marc0011's Avatar
If you're talking about the bar lock (immobilizer), then I highly doubt that's causing you your problems. I would pull the plugs to see if they're fouled. While you have the plugs out, I would do a compression test. If you have a cylinder or more with low compression, I would do a leak down test to see where the low compression is coming from. If you hear hissing from exhaust or intake, it's the valves. If you hear it coming from the case, it's the rings. If all that checks, check the starter valve synchronization. It's like a carb sync... just for the FI.
Old Jul 9, 2013 | 04:30 PM
Mojouk's Avatar
Default *
Thank you very much...ill show your diagnosis to my useless mechanic
Hopefully it should make more sense to him than me...
Knowledge is indeed power...
jtxfrjtxfr
Jun 11, 2012 01:37 PM
Cdp600rr
Feb 28, 2011 12:52 PM
tweeaks
Mar 23, 2009 10:00 PM
Goathumper
Sep 2, 2008 08:17 PM
sox0804
Jan 25, 2008 07:07 PM
