CBR 600 09 fairing work on and 08
Old 01-12-2011, 04:30 PM
rad671's Avatar
Default CBR 600 09 fairing work on and 08
Will the cbr 600 rr 09 -10 fairings work on a 07-08 cbr 600 rr
Old 01-12-2011, 06:06 PM
R Dub's Avatar
October 2011 ROTM
Are you talking about a entire kit or just a piece or 2?
Old 01-13-2011, 08:37 AM
rad671's Avatar
the whole kit
Old 01-13-2011, 10:07 AM
R Dub's Avatar
October 2011 ROTM
They look to be extremely similar with 1 minor hiccup. If you look at the links below you will find that the only real difference is the plastic piece that covers up the clutch and stator cover. All the bolts seem to be in the same spot on the 2 models. The hiccup is the bolt that holds the fairing to cover the clutch and stator which is right where the frame bends down. When looking at the 07's I do not see a spot to attach a bolt where the frame bends. Every other thing is the exact same though so if you can figure out how to make this work and attach a bolt then yes the whole kit will work. I hope all this makes sense.
http://www.bikewalls.com/wallpaper/H...1680x1050.html
Old 01-13-2011, 03:55 PM
rad671's Avatar
ok i see there is a PART #( 64462-MFJ-A40 )STAY, L. COWL (LOWER/UPPER) and STAY,R. COWL (LOWER/UPPER)
Old 01-13-2011, 05:41 PM
vangill's Avatar
July 2010 ROTM
yes they will fit but u wont have one bolt mount(on each side), youll have to buy it separate. it goes around the engine covers kinda on the top
fatboyslim86
05-06-2012 04:35 PM
Smiles w/ Bugs
10-22-2011 08:52 PM
super600
06-28-2009 09:57 PM
clcmbtn
03-20-2009 07:08 PM
vdubracer33
02-15-2009 12:48 PM
Quick Reply: CBR 600 09 fairing work on and 08
