CBR 600 09 fairing work on and 08
They look to be extremely similar with 1 minor hiccup. If you look at the links below you will find that the only real difference is the plastic piece that covers up the clutch and stator cover. All the bolts seem to be in the same spot on the 2 models. The hiccup is the bolt that holds the fairing to cover the clutch and stator which is right where the frame bends down. When looking at the 07's I do not see a spot to attach a bolt where the frame bends. Every other thing is the exact same though so if you can figure out how to make this work and attach a bolt then yes the whole kit will work. I hope all this makes sense.
http://www.bikewalls.com/wallpaper/H...1680x1050.html
