BURNED OUT MY cbr's ECU CPU??
Old Feb 21, 2008 | 12:52 PM
  #21
pop's Avatar
pop
Default RE: BURNED OUT MY cbr's ECU CPU??
If you find out what is causing this, please post up. I've got the same problem.
My bike is stock.
My battery was dead. Charged it on a trickle charger put it on the bike. It started and ran fine. Put a battery tender on it so as to keep the battery good and the next time I tried starting it no fire. I tried starting it with the battery tender still attached. (don't know if this makes a difference but I'm trying to give you all the info.) When I turn the key on now the gauge cluster cycles, the fuel pump primes, but when I hit the button the starter turns the motor but the motor doesn't want to fire.
Old Feb 23, 2008 | 09:55 PM
  #22
pop's Avatar
pop
Nevermind. My problem was solved. A little to much fuel in the cylinders was my problem.
Old Feb 23, 2008 | 11:40 PM
  #23
romano007's Avatar
as you were saying the battery is old how about borrowing a battery or charging the one you have and see if that works out. I personnally think it's the battery that is the cause. Cheap battery last about a year while that one that are over the 100 dollar mark can last 3 to 4 years.
Old Feb 24, 2008 | 12:29 PM
  #24
cosme017's Avatar
my friend and I had the same problems. the majority problem with batteries in a cbr is the regulator/rectifier. Its a pretty cheap part, but it might be worth trying to see if thats the problem
Old Feb 24, 2008 | 11:00 PM
  #25
icon skull's Avatar
Registered Users
yes he does
Old Aug 2, 2017 | 02:24 AM
  #26
Zahid Shah's Avatar
As i understand it, you are getting power from your battery at "IGNITION ON", the fuel pump primes, the meter cycles, and the starter is turning the crankshaft when you press the start button. what you are lacking is the big BOOM that happens soon there after. It's not sputtering at all, correct?[/QUOTE]
Brother!!
i got the same problem 2 days ago! And as you have described, it is exactly the same thing. Kindly, help me out if you know the sloution?
Old Jul 11, 2020 | 02:09 PM
  #27
Jbaer1990's Avatar
Default 02 cbr f4i 600
Trying to diagnose no start with my 02 cbr f4i 600 it has injector pulse and cranking I have rpm gauge sweep when your turn the ignition on I’ve check the cam sensor and crank both are within ohms specifications. Thanks guys for your help
Old Jul 11, 2020 | 03:08 PM
  #28
74demon's Avatar
it would be best to start your own thread in the F4i section. This one is a 600rr thread from 12 years ago....
2013repsol
Jan 12, 2013 12:20 AM
halffast1g
F2 Tech
May 27, 2010 08:17 PM
ugly
Aug 11, 2009 11:11 PM
tjripper14
Aug 25, 2008 08:32 PM
Amaese
Feb 22, 2006 01:24 PM
