break in????
Old Jul 21, 2006 | 01:25 AM
jasonb's Avatar
Default break in????
So you are supposed to break in a new bike??? dealer guy never let me know of that when i left with it.
i got a 06 cbr 600 rr lemme know how u guys are breaking it in..
I think i broke it in good the first day i had it!
Old Jul 21, 2006 | 01:36 AM
knightslugger's Avatar
Default RE: break in????
Yeap. new engines must be broken in. Vary the RPMS and no 12k shifting. there's a lot of metal bits in the oil and you'd be wise not to test that ****ty oil. Change oil at 600mi. It's up to you weather or not you want to go Full Synthetic because after the brake in, it really doesn't matter.
the other method is to Run the **** out of it durring the first 30 minutes of operation at warm engine temp. I have heard conflicting debate about this method so i took the dealers advice and just varied the RPM. Running around town on short roads with lots of stops is probably best, that way you vary the rpms a LOT.
Old Jul 21, 2006 | 01:23 PM
FFonaRR's Avatar
there is a post somewhere in june with a bit of this discussion. Honda says they dyno the motor before it leaves the factory so it requires no break in. That is supposedly why other manufacturers put a break in sticker on the tach. Never seen one on a honda and i bought my 05 600RR new and rode it off the floor the same way I ride today. Currently 6k miles and other than replacing brakes (cause i sometimes ride like an *** ) no probs. I did switch to Hondas semi synthetic at the 600 mile service.
Old Jul 21, 2006 | 07:55 PM
scouperacer1994's Avatar
If you want your bike to last... Try, as hard as it is, to shift before 4k rpm untill 600 mi then 8k untill 1000mi, but make sure you do as many easy turns as you can because the new tires have a light film of some sort of oil on them try to get it all off b4 you get to nutty in the twisties. other than that if you take it easy your brakes should wear in normally. After you put 1000 mi under its belt thats when it time to go have some real fun.
Old Jul 21, 2006 | 10:28 PM
Fretless33's Avatar
It's a Honda...RIDE IT LIKE YOU STOLE IT...it can take it LOL!!!
Old Jul 22, 2006 | 03:45 AM
wickedambush's Avatar
IM WITH FRET..I GOT A BRAND NEW 06 600 TOO AND I RODE IT LIKE IT WAS HOT AND TOOK IT IN AFTER 800 AND THERE WERE NO PROBLEMS WITH IT.
Old Jul 25, 2006 | 12:07 AM
jasonb's Avatar
lmao!!!!!!
Old Jul 25, 2006 | 12:25 AM
MeyekulBayrd's Avatar
I put a little over 500 miles of shifting at around 5-6k and varying the rpm on my 1krr, then changed the oil at around 570mi. I still haven't pinned the throttle yet, I'm going to get around 700 or 800 miles on it before that.
Grego2582
Mar 27, 2013 06:13 AM
raylee
Mar 8, 2010 10:57 PM
alleycat
Oct 10, 2007 11:20 AM
ctskydive
Aug 20, 2007 05:23 PM
Drekkyk
Jun 9, 2007 12:00 PM
