Bolt Help
Old Sep 24, 2009 | 08:46 PM
The__Rider's Avatar
Default Bolt Help
Will these work on my 04 600 rr? I gives no indication of what bike it's for...please help!
http://www.chaparral-racing.com/Chap...E04D2F8760D8FB
Old Sep 25, 2009 | 11:57 AM
volcomrr's Avatar
considering it doesn't even mention the type of thread size, I would say NO.
Old Oct 4, 2009 | 11:21 PM
Shadowfax's Avatar
Cool
For metric fasteners typically the the thread size is the first # listed such as: 4mm x 6mm meaning 4mm thread by 6mm length. Metric threads are typically fine thread unless otherwise specified. I have worked with JIS Standards long enough to realize, however that just because a fastener seems to "match" what is called out in the Service Manual, I will NEVER replace a screw with anything but a Genuine Honda Part. The OEM's may have different tolerences, different metallurgy, even slightly different pitches than what I refer to as "Hardware Store Hardware". They're crazy tricky and smart, those Jap Engineers, and call me paranoid, but I will not risk cross threading a tapped hole in my frame to save a few cents on a screw...
Old Oct 4, 2009 | 11:31 PM
Shadowfax's Avatar
Also if you look at the picture, all the fasteners are Socket Head Cap Screws, and if you glance at the side of your bike, you'll see that most of the screws are Button Head Cap Screws.
Old Oct 5, 2009 | 12:53 PM
The__Rider's Avatar
Yeah I already bought them unfortunately. Checked them, and they will not work because I don't even need them. What I was looking for was fairing fasteners. Hopefully the seller (from ebay) will refund the money. Thanks for your help anyways!
Old Oct 5, 2009 | 12:56 PM
The__Rider's Avatar
Originally Posted by Shadowfax
just because a fastener seems to "match" what is called out in the Service Manual, I will NEVER replace a screw with anything but a Genuine Honda Part. The OEM's may have different tolerences, different metallurgy, even slightly different pitches than what I refer to as "Hardware Store Hardware". They're crazy tricky and smart, those Jap Engineers threading a tapped hole in my frame to save a few cents on a screw...
So would you say that the only ones worth using are the Honda ones? Is there a place where I can buy the Honda bolts? A full set, colored?
Old Oct 7, 2009 | 01:26 AM
Mr_CBR600RR's Avatar
You can get the fairing bolts off ebay, google, and prob a powersport place can order them for you. They arn't the cheapest though. Check google and ebay first, if you dont find something for a decent price, I say call up a powersport place and ask them. They will find and order you the correct bolts. Just make sure when you look for bolts, you make sure they come with the nuts too or else you'll be stuck with more random screws haha!
Old Oct 9, 2009 | 11:53 PM
The__Rider's Avatar
I got everything I needed, thanks for your help!
toxzzic1
Mar 8, 2013 12:19 AM
chambers
Mar 23, 2012 05:10 PM
Campbell45
Jun 16, 2010 12:54 AM
crashkhanman
Jan 21, 2008 01:11 AM
gtjimm
Jul 11, 2006 03:37 PM
