07 Starts up perfect, then boggs down
Old Mar 20, 2021 | 03:43 PM
ImpulsiveJames's Avatar
Default 07 Starts up perfect, then boggs down
This has been happening since I got my valves checked. When I start the bike, it starts perfect and idles a little higher (since it's cold), but after about 20-30 sec, the idle drops and is just way too low, blubbing almost like it's going to die, but not quite that low.
The bike runs great and there isn't any throttle issue, it's just mostly at stop lights and normal idling you can tell it's too low.
Thoughts?
Old Mar 20, 2021 | 05:47 PM
A few more tidbits of info.
When you turn it on, it goes straight to 2k to warm up, then exactly 30 sec later it drops to about 1200, after that it will occasionally work it's way up to about 1700 for a split second then fall back down to about 1200 again and repeat. It's not a fast up and down.
Old Mar 21, 2021 | 11:31 AM
So you're saying this was not happening before you had your valves looked at, and now it is doing it? I'm seeing a pattern here. Where did you have work done and what exactly did they do? Were any of the clearances out of spec? If so, they had to remove the cams and that lends itself to potential mistakes.
Old Mar 22, 2021 | 05:24 AM
Doc Samson's Avatar
Have you checked for any possible vacuum leaks or lines that didn't get put back on? When I did my valves I had a little vacuum tube that I forgot about and that caused a bit of a problem...
jeremymik84
Sep 4, 2024 03:50 AM
ebag600
Oct 6, 2020 02:08 PM
wes 17
Aug 5, 2017 04:51 PM
SBU600RR
May 29, 2008 03:06 PM
bruingoal6
Nov 20, 2006 07:52 PM
