Why is this spewing brown??
Old 04-18-2008, 06:21 PM
lotusgardener's Avatar
Default Why is this spewing brown??
Ok,
I've been having problems starting my bike-if you've read my other posts I bought the bike damaged. Finally got it started today, just walked up to it, put the key cranked it over - started!
So i ran inside to pee (cause I really had to), so the engine warmed up. Now I'm hooking the airbox back on and all of sudden when I hook up that hose in the picture, the bike starts dying, so I unplugged it. Then it reached operating temp, and brown liquid starts spewing out. It's liquidy like gas but brown with oil - if that makes sense.
Let me know guys.
[IMG]local://upfiles/8405/58070A7088164EC6B277B41242AD5116.jpg[/IMG]
Old 04-18-2008, 06:56 PM
sorny's Avatar
Default RE: Why is this spewing brown??
was the bike water damaged/flooded?
Old 04-18-2008, 07:13 PM
Nauree's Avatar
Thats a vent hose. No fluids should come out of it so that means you have a seal problem inside.
Old 04-18-2008, 07:21 PM
dirtdobberoffroad's Avatar
Maybe a head gasket letting blow by and the watery oil come out the vent tube. But I hope not for your sake.
Old 04-19-2008, 12:18 AM
brveagle's Avatar
crankcase breather. It is possible to have some oil come out of it, but that would be from a pressurization of the top end. It looks like you have alot of oil.
When was the last time you changed your oil? Try pulling the valve cover (about 20 min) and seeing what that shows.
Old 04-19-2008, 08:10 AM
ORIGINAL: dirtdobberoffroad
Me neither... But I checked compression - 160 across the board so wtf!!
brveagle - If I have time today, I'll pull the valve cover, do I have to take the carbs off for that???
Old 04-19-2008, 10:18 AM
Nauree's Avatar
ORIGINAL: lotusgardener
^yes
Old 04-19-2008, 12:55 PM
No you dont have to pull the carbs off to get the valve cover off but its kinda a butt.
Old 04-21-2008, 07:55 AM
brveagle's Avatar
Every time i pull my valve cover, i just pop the carbs out of their boots real quick. Otherwise the choke rail gets in the way.
Old 04-21-2008, 05:45 PM
ah I see I just took the Choke cable thingy off, Now I can see Y.
June6th1944
10-30-2011 12:19 PM
Clos
10-25-2009 09:42 AM
marc0011
10-18-2008 06:49 AM
jmanng
11-24-2007 07:29 PM
VP
12-01-2006 01:46 AM
Quick Reply: Why is this spewing brown??
