carb's spewing fuel
Old Sep 23, 2009 | 07:54 PM
Clos's Avatar
Default carb's spewing fuel
ok. today i removed carbs, b/c choke acting funny and #4 carb leaked at the bowl seal. fixed both problems, but now, my carbs are spewing fuel at the 2 hoses on top. i ended up cleaning the float filters, fuel filter, and choke guides, pins, whatever you call em. but i'm spewing fuel. are my floats somehow stuck open and over flowing? thanks for any help!
Clos
Old Sep 23, 2009 | 08:05 PM
joeroberts's Avatar
I well have to say yes!
make sure you have not damadged the rub tip of the pin and check the float level settings.
Old Sep 23, 2009 | 08:30 PM
Clos's Avatar
prob is i don't have that "special tool" lol
Old Sep 23, 2009 | 09:12 PM
KongBastard's Avatar
Don't worry about the float levels, they are probably okay - if they worked before. The only thing that you should watch for with the floats is to make sure one haven't cracked.
You have something stuck in the float assembly/valve. Clean them again.
KongBastard
Old Sep 23, 2009 | 10:28 PM
Clos's Avatar
well i did find, that 2 of the float pins? ( little sticks with rubber tips,) have a little pin in the top that's springy. 2 of em didn't move, and i got them un stuck. i guess i'll just have to take it back to work and remove the carbs and try again *sigh* thanks for the help. so i guess just make sure all the floats at least look level when upside down then?
Old Sep 23, 2009 | 10:48 PM
Billistic's Avatar
You need to measure the float height when you have them open. There is a set measurement that they must be at to function properly. Measure the float level with the carb inclined 15 -45 degrees from vertical so that the float tang just contacts the float valve. Float level= 8mm ( 5.8" ). Buy yourself a small metric ruler.
Old Oct 23, 2009 | 01:01 PM
wig's Avatar
wig
Default jjkki
i had the same problwm with my cbr400, i was advisewd to remove the floats, remove the needle valve, and gently rub the rubber tip of the vavle seat down with some abrasive sponge or something.
just gto remove the ring that can form or the glaze.
i did this and nowe they are fine
Old Oct 25, 2009 | 09:42 AM
tds94probe's Avatar
Billistic hammers it out of the park!
cc rider
Mar 30, 2013 07:59 PM
June6th1944
Oct 30, 2011 12:19 PM
lotusgardener
Apr 21, 2008 05:45 PM
jmanng
Nov 24, 2007 07:29 PM
nkx
Apr 5, 2006 03:48 PM
