help chain and sproket kit
Old Apr 17, 2008 | 10:44 AM
cbr600f4rocks's Avatar
Default help chain and sproket kit
hey, i am new to the forum, i have a 99 cbr 600f4 and i need to replace the chain and sprocket, what is the best kit to use? i want a good one but also want one that will last and not wear out quick. thanks for help.
Old Apr 18, 2008 | 01:04 PM
LIM118469's Avatar
Default RE: help chain and sproket kit
i would say pretty much any of the the more well know companies should do u fine, so long as u replace them(front, rear sprocket, and chain) all at the same time
Old Apr 18, 2008 | 02:22 PM
gmay00's Avatar
From what I've read on here also, it sounds like you would want to stay with the stock 325 chain. It's a bit heavier than the 320 chainthat most people convert to,but the 325 lastslonger. As far a brands, I'd say just stay away from the cheap ones as chains are one thing you can't take a chance on...
Old Apr 18, 2008 | 09:19 PM
what is the difference about the 325 and 320 chain and about how long do they last? and what about the sprockets, i see most people -/+ on sprockets what is the advantage of doing that? if you -/+ does that change speedometer and also is it a direct replacement or do you have to change anything? thanks for the help and responses.
Old Apr 20, 2008 | 08:58 PM
jessej05's Avatar
do u mean 525? and 520 conversion? cuz i went to the store and they said mine takes a 525 stock..
Old Apr 20, 2008 | 09:22 PM
toaliosis's Avatar
Yeah, they meant to say 525 and 520
Old Apr 21, 2008 | 11:14 PM
travsf4's Avatar
a 525 chain will last a little longer than a 520 people change to a 520 for lighter weight for racing. I never noticed a difference.
changing the teeth on the sprockets are just like a bicycle up 3 teeth on the rear is the same i think as droping 1 tooth on the front. this gives you faster acceleration. going the oposite will give you less acceleration and more top speed but i have never heard of anyone doing that. The speedo from factory is off 7% changing the sprocket size can take it out 15%. It says your faster than what you are. The first time i droped a tooth i reached a top speed of 295kms on the speedo but i wasn't really go that fast. to bad eh.
gregtutch
Oct 6, 2009 07:52 AM
nrecore0223
Apr 16, 2008 08:44 PM
chris411820
Jan 5, 2006 06:16 PM
05Tribal
Dec 2, 2005 07:46 PM
wheeliemonster
Apr 5, 2005 01:43 AM
