Turns over doesn't start after carb clean
Old Sep 29, 2012 | 05:33 PM
Brandon Henson's Avatar
Angry Turns over doesn't start after carb clean
Ok I've removed my carbs tons of times I even installed my jet kit. This time figured while had carbs and everything off would flush coolant and change oil. Did all that cleaned carbs reassembled everykthing perfectly. But when I went to start my bike it just kept turning over would never ignite.. So I'm guessing maybe I fouled the plugs. Only thing I can think of I'm about to change them just wanted your guys opinion. All it does is turn over.
Ps really dumb question lol but when I reassembled my throttle cables to carbs and checked to see if they were where I wanted them I gave the throttle alittle tug and it didn't move. Somehow I reversed something instead of pulling the throttle towards me to accelerate now I have to turn it up towards the rear brake and. Don't want to pull carbs off again to get easy access at the throttle mechanism to see what I did wrong so if anyone has any clues lol about any of this it would be greatly appreciated
Old Sep 29, 2012 | 05:36 PM
Ok update changed the plugs and realized it should still try and start with fouled plugs so yeah. Needed changing anyways. However it still just turns over doesn't even sound like she's trying to start. I went back checked to make sure all hoses were reconnected and in correct order and they were. Could have something to do with fuel pump but I didn't even touch that and it worked perfectly fine yesterday everything did in fact I just decided to do a routine tune up which I have done a thousand times and now I'm stumped.
Old Sep 29, 2012 | 05:58 PM
sccbr600's Avatar
Did you cycle the key off and on like a million times to get has back in the carbs?
Old Sep 29, 2012 | 09:59 PM
No is that required don't remember doing that before I'll give it a shot tomorrow if anyone else has any suggestions I'd greatly appreciate it. And thanks sccbr600 I'll give that a try it makes sense though with the fuel pump coming on when key is turned so yeah.
Old Sep 29, 2012 | 10:56 PM
Lol well went out there primed it a few times and she sprang to life and that full yoshi exhaust roared through my apartment complex lol ppl were probably pissed but I didn't care thanks for the help don't forgot about priming it but thanks again
GorgeousHellion
Feb 29, 2012 05:22 PM
brennanand
Jun 30, 2009 05:40 PM
jahnaboi
Feb 17, 2008 10:02 AM
Bobinbaghdad
Apr 25, 2007 01:01 AM
weeble1
May 7, 2006 02:39 PM
