Starting trouble
Old 02-01-2009 | 11:34 AM
agencyf4's Avatar
Default Starting trouble
So I decided to day it was nice out and I wanted to start the CBR for a little while. Put the battery in and it wouldn't start. Relay clicks, starter clicks, and turns maybe once very slowly. Took the battery back out to try and charge it somemore and it did the same thing again. Should I be getting a new battery or should I get to the starter? Lights and gauges all light up as well.
Nate
Old 02-02-2009 | 10:56 AM
MartiniRossy's Avatar
I would be 99% sure that your battery is weak but there is the possiblility that your starter is drawing to much current. Low amp charge the battery for 1/2 a day and bring it in to a parts store somewhere and have them load check it.
Old 02-02-2009 | 08:06 PM
platnumbob's Avatar
That clicking noise is exactly what happened to my when my battery was not fully charged and it was cold out. The terminals may have also been dirty at the time. Check your connections and battery first.
Old 02-03-2009 | 05:16 PM
CB750's Avatar
I'd second this, but to go from the charger right to the bike doesn't always have good results. Might sound a little strange, but what you tend to get is a "surface charge" where you have good power for a short time. Put it on a trickle charger for a few days, that'll let the charge "soak in" and give a good deep charge that'll last.
gonzosport9
07-03-2013 02:24 PM
jbomb
04-18-2013 07:22 AM
DragonCBR
05-30-2009 09:40 PM
bluestanger66
06-23-2007 09:52 AM
9two9
05-08-2007 01:06 AM
Quick Reply: Starting trouble
