shifting problem?
Old Sep 21, 2009 | 05:56 AM
HKchucksta's Avatar
Default shifting problem?
Hey all, more problems (again D: ) from my bike. It seems to have trouble shifting from 1st to 2nd. It'll find neutral and then refuse to hit second, sometimes i can hear the gear hitting the clutch (like a machine gun, it doesn't sound pretty) but it just refuses to engage and I look like an idiot revving at maybe 15 mph with people behind me. It'll eventually engage if i kick up enough times, but it's definitely a problem.
Is this maybe a problem with the starter clutch? I have no idea.
Old Sep 23, 2009 | 10:12 AM
CaliKush's Avatar
are you rolling down a hill in neutral? that happens to me but its normal.. unless ur on like a flat ground then i dont know..
Old Sep 24, 2009 | 11:57 PM
Naruku's Avatar
Clutch cable maybe? Could have some slack in it.It's always good to start with the simple fix first.(or could use a lube)
Old Oct 4, 2009 | 10:16 AM
dirtdobberoffroad's Avatar
Shift forks bent I think. I have the same problem and I got a new set of shift forks and shift drum so when I finally split the case I hope I havn't messed up the 2nd Gears....Good luck. on second thought check the linkage between the shifter pedal and the shaft. make sure its not real loose... that might be the problem
Old Oct 6, 2009 | 06:36 PM
turk in gm's Avatar
I have this problem too. not good at all. im going to post another thread about this because it also happens to me in my 3-4 shifts.
Atrom
May 11, 2011 05:21 PM
kiddrew77
Jun 22, 2010 07:44 PM
Dj_Squatch
Jan 26, 2008 08:25 PM
CBRrider01
Jul 9, 2007 11:40 PM
fullmetalf4i
Jun 9, 2006 10:53 PM
