Season Oils
Old Nov 21, 2006 | 04:43 PM
ddvs's Avatar
Default Season Oils
Do you all change different types (Density, Cooler Running Oils) of oils during dif. seaons? Also I've ran normal Factory Honda Oil that comes in the Red 4 liter jug and I want to start running full synthetic. Is this going to cause any severe/ permanent changes, and is this recommended? I have about 45 thousand miles on my bike and I'm due for a sprocket and chain change as well as an oil change and a carb sync and I want to start knocking these things out with each paycheck. Let me know what you would recomend! I appreciate ANY INFORMATIVE responses.
Old Nov 22, 2006 | 04:03 AM
Spastik Monkey's Avatar
Default RE: Season Oils
I run repsol full race oil at the track and castrol superbike on the street. Both are incredible full synthetics, definately worth the money.
Old Nov 24, 2006 | 02:08 AM
CBRF4's Avatar
is it bad to run the race oil on the street?
Old Nov 28, 2006 | 05:51 PM
ddvs's Avatar
it would probably be bad to run race oil on the street because race oil is intended for track use right?
Old Nov 28, 2006 | 10:40 PM
CBRF4's Avatar
what oil is the best to use everybody tells me something different i really want to know so i can stick with the best. is syntetic oil better then regular oil? What oil do you guys use on your bikes? thanks
Old Nov 29, 2006 | 02:49 PM
ddvs's Avatar
most of us (can't speak for us all) run synthetic or Honda JP4 oil.
Old Jan 28, 2007 | 06:37 PM
Sinner's Avatar
The full synthetic oil is better for lubrication and for keeping the engine parts in better shape.
This doesn't mean that the semi-synth stock used is poor.
The racing oils are made because the high revs that are used during the track. There's no problem riding race oil on street.
horse_power777
Mar 27, 2011 08:14 PM
Showtime_III
Mar 15, 2009 12:06 PM
Y2kBlade
Mar 2, 2009 10:49 PM
AudiCBR
May 21, 2007 12:24 AM
peterk
Sep 10, 2006 09:41 PM
