oils ain't oils!!!
Old Sep 6, 2006 | 09:32 AM
peterk's Avatar
Default oils ain't oils!!!
Am doing a bit of (probably overdue) maintenance, already have the oil i'm going to do change with but received this info below from a bike shop today and wondered what oil others are using??? peterk
"3 main oil types are mineral, mineral oils with an ester base (semi-synthetic) and fully synthetic oils. What oil you choose will depend on numerous factors like; your type of riding (commuting, racing, ride days and weekend blasts etc.), engine configuration (V-Twin, In-line 4, Single etc.), age of engine (air cooled or water cooled) and wear and tear the engine has been exposed to."
Old Sep 6, 2006 | 09:41 AM
Default RE: oils ain't oils!!!
This is one of the best sites I've found for understanding motor oil. It has more information about Oil than I ever wanted to know. He also has a great section on oil filters.
http://motorcycleinfo.calsci.com/Oils1.html
Old Sep 6, 2006 | 10:19 AM
MarkR's Avatar
I'm using Shell Advance SX4, but I have clutch slip under max load, (I think when the bike is cold).
I am thinking of changing, My new mechanic (mechanic No 4, so far, it called elimination) uses Motorex and recommends a semi-synthetic.
any thoughts?
Old Sep 6, 2006 | 12:05 PM
cbr_lover's Avatar
I'd say the CBR1000F's engine isn't highly strung enough to warrant fully synthetic oil....I've always used
a good quality semi-synth in my CBR with no probs whatsoever.I think regular oil changes are quite important
to the life of an engine so change min every 2 - 3000 miles.
Brands of oil i've used and recommend are
Silkolene
Castrol
Morris - (which is in the bike currently)
Am i the only one who thinks fully synth ain't required for the CBR1000F,or are any of you running it in yours?
Old Sep 6, 2006 | 05:26 PM
Noe's Avatar
Noe
I run full synth 15W-40 in mine right now, but I talked too a guy yesterday whom have been riding CBR1000F's for many years, and he ment that a semi synth was more than good enough for the bike... So I might try that the next time.
Old Sep 6, 2006 | 09:41 PM
Trips's Avatar
I used to use Diesel because of its ability to cope with shear!
But I now use Mobil 1 fully synthetic. To be honest tho' the only reason I use fully synthetic is because I get it cheap.
If I have to pay normal price then I would just go for a Dino or semi dino.
But the main thing to consider is how often you change rather than what you use.
Old Sep 7, 2006 | 10:02 AM
peterk's Avatar
How many k's/miles between oil changes and do you change the filter every oil change???
Old Sep 8, 2006 | 02:43 AM
Trips's Avatar
I always do 5000km and change the filter every time.
Old Sep 9, 2006 | 06:08 AM
peterk's Avatar
Trips, how many changes a year? or how many k's a year. was in perth in the early '81, nice place, went to the Black Duck Rally, ever heard of it, is it still going???
Old Sep 9, 2006 | 10:10 PM
Trips's Avatar
Never heard of black duck rally. But only been here for 10 years so I am not counted as a local.
The Roads suck, but the weather's great. The twisty ones are all bumpy gravel ridden goat tracks. The one the Brockie died on was a favourite bike hoon road. Of course now it will be full of sightseers and mourners etc.
I do about 40,000 a year so I go through a lot of oil changes.
