Please help! ... Low / no compression ... 2000 F4 died while riding, now won't start
Old Oct 6, 2008 | 09:21 PM
Ernie518's Avatar
Default RE: 2000 F4 died while riding, now wont start
How damaged does the piston look? Does it need to be replaced?
Would this cylinder head work? It is for an F4i, does that matter?
F4i cylinder head on eBay
Old Oct 6, 2008 | 10:31 PM
jonld's Avatar
I cant really tell the damage to the piston from the pic. is the piston cracked? if there are no visible cracks or holes it is probably ok. As for the f4i head, Ive heard its been done, so you could search forum for that. I dont see any cams with that head either.
Old Oct 6, 2008 | 10:54 PM
Ernie518's Avatar
No, the piston's not cracked, it moves smoothly within the cylinder.
Any ideas what may have caused this to happen in the first place? I'd hate to get a new part and then have the new part fail after a week due to the same thing.
Anything else I need to check? Thanks!
Old Oct 6, 2008 | 11:02 PM
mikebluep5's Avatar
it would honeslty be more cost effective/better piece of mind to just buy one off a wrecked bike and swap it. the one you have now will need to be torn down and completely gone through to make sure theres no pieces left in it, so youre looking at a complete gasket set, everything basically. new head, timing chain, etc etc. the list would be forever long of tiny things.
Old Oct 6, 2008 | 11:06 PM
Ernie518's Avatar
Swap out the whole engine?
Old Oct 6, 2008 | 11:09 PM
mikebluep5's Avatar
what type of oil and what intervals were you running? the only other culprit could be a blockage or pump. I used to remanufacture cylinder heads for a living. that head you have is no good except for scrap metal. you could salvage the valves that arent bent, the lifter buckets and shims, springs that arent broke or weak, retainers and locks, MAYBE the exhaust cam (the bad one was on the intake side right, im too lazy to check the pics again), the sprockets, and i think thats about it. IF you wanted to go the CHEAPEST route you could get another head and see what happens, but I would do a thorough teardown and go over evertything in the block to check for wear and clearances. Also cleaning is your best friend.
ORIGINAL: Ernie518
Old Oct 7, 2008 | 09:32 AM
jonld's Avatar
Do you do wheelies? I still wonder why you only had oil starvation on #1. You could buy another engine out of a wrecked bike, but you still wouldnt know its internal conditions either. If it were me I would either buy a diff engine and hope for the best, or I would buy another head flush the engine to recheck for metal shavings(I know you said you didnt find any before) put it back together. Verify CCT is functioning right. Probably would leave valve cover off( I know its gonna make a mess) to see if its pumping oil to all cylinders. I can't figure the oil pump being bad if the other 3 cylinders were lubing fine. I would bet on a blockage, but the questions is where, in the bad head?
Old Oct 7, 2008 | 04:59 PM
mikebluep5's Avatar
there definantly looked like metal shavings to me in the pic of the oil pan. up in the corner.
Old Oct 7, 2008 | 07:01 PM
Ernie518's Avatar
No I don't do wheelies, but I don't know about any owners before me. I bought it used just about 2 weeks ago.
Are the metal shavings from the cylinder head? The cylinder head was pretty messed up.
Old Oct 7, 2008 | 10:19 PM
mikebluep5's Avatar
Most likely, but i would go ahead and tear the bottom end down as well. Check the rods, mains, wrist pins etc if you plan to reuse the bottom end. If not go ahead and tear it down anyways just for the fun of it just to see what it looks like. That will give you a clue as to the maintenance thats been done.
psalas3
F2 Tech
Jun 22, 2015 11:45 AM
Jab_da_man
Jun 1, 2010 10:50 AM
toaliosis
Jul 30, 2008 07:28 PM
mikey1011
Oct 16, 2007 08:03 PM
Saved_one
Apr 20, 2007 10:49 PM
